Books? No. Every piece if text I've read on the topic is either too theoretical or too dumbed down, nothing in the middle. However if you're not 100% committed to text format, this thread has some excellent videos on the topic.AAC is always a good place for recommending books.
Any recommendations for a good book on PID controller theory and implementation.
I agree with you on dumbed down - there's way too much of that out there with our 1 minute attention spans. (AAC is guilty of this)... is either too theoretical or too dumbed down.
That's the type of non-linear condition, that a PID controller may need additional circuitry to handle.That must be the point where the output impedance changes from almost infinite to almost zero.
Glad you found that post helpfulThanks everyone.
Bob Pease’s article is, as always, brilliant.
I located an old edition of Franklin, Powell & Emami-Naeini, for £4.35, which is rather better that the £253 that they wanted for a new copy, and decided it was really time I owned a copy of Jim Williams’ book.
Depends on the plant - every plant is different and we clearly don't know your plant. It also depends on where your integral and derivative terms are sourced (Kp, Ki, Kd vs Tp, Ti, Td, digital vs analog, etc.)Then I decided to have a go, and applied it to a thyristor battery charger, with pretty good results.
Would I be expecting the Integral and Derivative terms to be quite small?
I never thought it was the best thing to try it out on! It was just convenient.That's the type of non-linear condition, that a PID controller may need additional circuitry to handle.
Perhaps a change in the PID parameters are needed when the transition is made.
While they do resemble each other - they are NOT the same. Further analysis will show that Type III only allows for real poles/zeros while PID can implement complex poles/zeros.I was struck by how much this resembles the type III compensation amplifier for switched mode power supplies.
(Figure 32 in https://www.ti.com/seclit/ml/slup340/slup340.pdf )
Rcomp is ”proportional”, Ccomp is “integral”, and Cff is “differential”
Even Chf fits, as it is the single sample period delay.
I suppose it stands to reason, really.
Yes.I was struck by how much this resembles the type III compensation amplifier for switched mode power supplies.
