Indeed and that would be perfect. I fear that flow control measurement is a little expensive.Could you use distillate flow rate as the monitored variable for feedback to the controller?
You're describing latent heat. You can put a pot of pure water on the world's hottest stove, an acetylene-powered monster stove, and the temperature of the water won't go over 100C. Latent heat is the phenomenon that occurs at the temperature where a given substance changes state from solid to liquid or liquid to gas, or back again.The problem with the boiling point is a function of the solution (liquid) which is a combination of many components each with a different boiling point. As these components are driven off the boiling point of the solution intrinsically alters.
When you set water on a stove in a pot at 1kw and it will boil at 94°C (well certainly where I am from), if raise the power to 2kW the water will still boil at 94°C but there will be more steam due to the increased power. The increased steam for us is increased volume output. So you can control the output of water vapour by simply applying more power.
If you put a pot of alcohol wash on the stove and set it to maintain the solutions boiling point, 78°C. The lower BP components will boil off as the their BP is reached which in turn alters the BP of the solution. As the lower BP components have boiled off the average BP now increases. However the stove is set to 78°C and will maintain that temperature. The result is that the process has now stalled as any substance with a BP of say 80°C will not be able to evaporate. So one now needs to lift the temperature to say 81°C, and the cycle repeats.
If one was to say set the PID to reach 94°C to avoid all these adjustments then the amount of energy required would increase the output past the pencil lead trickle, the condenser would not have sufficient capacity to cool the distillate and the alcohol % would reduce. All undesirable attributes.
It is for this reason that some argue that controlling the power into the still is better than controlling temperature. The PID lads insists that PID's are best but they are not technical enough to explain it to me who probably would not understand.
Bomb? Really?The problem with a calibrated hole is that you have a pressure vessel with a finite hole, filled with highly volatile liquids, in short you have a bomb.
How about technological progress?For hundreds of years distillers have been using boiling a kettle with a simple fire beneath and then condensing the vapour to make alcohol, it is deceptively simple
5000w ac 220v high power electronic regulator scr voltage regulator module Sale - Banggood.comDo you have a p/n for this 4kW thyristor controller?
For hundreds of years distillers have been using boiling a kettle with a simple fire beneath and then condensing the vapour to make alcohol, it is deceptively simple. The problem with a calibrated hole is that you have a pressure vessel with a finite hole, filled with highly volatile liquids, in short you have a bomb. Now one would have to fit a pressure release valve. I distill purely for home consumption and make a couple of bottles of Gin every now and then. So I am mindful of the the cost vs. benefit factor.
Not for a home-made gauge. A simple gauge operating on the tipping-bucket principle would suffice for moderate flow rates. Or if the flow rate is low then an opto-sensor could be used to count drops of distillate.I fear that flow control measurement is a little expensive.
This is frustrating. Frustrating to know exactly the solution to someone's problem and spell it out over and over, only to have them throw their hands up in defeat as you hadn't said anything at all. It's like trying to convince a woman to leave an abusive relationship.I think that I will simply stick with my voltage controller, it works. KISS probably is best at my knowledge level.
The only time you should never fail is the last time you try. Besides with that information I think I'll start a microbrewery I mean in-house for personal consumption thank you sir.Maybe if I had explained things better. Oh well, maybe next time.
I don't see why. Did you read post #29?If we could use the flow meter as a variable for the PID then a different story, but now the cost of control moves past the average home distiller budget.
I did I have been googling flow meters and PID's tonight to see if they are cost effective.I don't see why. Did you read post #29?
A digital rainfall gauge perhapsCan you make your own flow-meter? A micro-tipping-bucket type would be low-cost.
Control liquid flow:However when you observe a solid stream of circa 2mm diameter, this delivers product in the range that is desirable.
Mmm that's rather elegant, mmm gonna muse on this one,Control liquid flow:
For stream 2 mm diameter calibrating hole should be 2mm diameter too.
Or use valve instead calibrated hole, then you can set desirable diameter of stream manually.
