PICkit 4 now available
Travm
Joined Aug 16, 2016
363
+1 for Dave, guy's an animal.
Whoever comes across it first should link it to this thread so we can all share the Aussie excellence.
MaxHeadRoom
Joined Jul 18, 2013
30,784
I guess it is bye bye for using MPLAB-IDE with it, too bad they don't make thier stuff downward compatible.
As the video by Dave outlined.
Max.
Raymond Genovese
Joined Mar 5, 2016
1,653
I have been using MPLAB X IDE for a while and I actually like it quite a bit (v5.10). I have started to focus on pic32 (using XC32 v2.10). This is not a trivial effort, at least to me. If you think that going through an 8 bit data sheet is daunting (not saying that you do) try a much larger family data sheet and then another 15-20 very large and specific data sheets for all of the functions/categories.
I reached a decision that I would do what they (Microchip) want because, in my view it is easiest and best until I get to a point where I can see otherwise. IOW I am trying to look forward.
That also means deciding not to use any legacy peripheral libraries. They even issue a warning that they will likely be dropped in future xc32 versions. That means getting into the Harmony libraries. That does not mean, however, getting into Harmony projects. I wanted to stick to the CCI (Common C Interface) but I simply can't adhere to the no no sub-directories rule in the header specification. Once I am far along in my understanding and familiarity, I will go back and simply use correct paths. But, right now, I run into so many dependencies the paths get too funky. Again, give me some time.
Of course I am not happy about the price for an optimized xc32, but it is only a hope that it becomes a problem some day. In fact, taken together, all the compilers, the IDE, the assemblers...all free, it's pretty awesome.
Anyways, that's my story and I am sticking to it :)
When you get to the point where you can see otherwise there is always the MIPS toolchain if you want 'Bare Metal'.
https://evosyn.com/pic32img.html
This guide is for those who don't want to use XC32 or would like unrestricted optimisation options without paying out for the non-free Microchip compiler.
Since the PIC32 has a MIPS core, the Imagination Technologies (Who own MIPS) toolchain can be used to generate object code. Most programs should be able to be ported with a little effort.
"Codescape GNU Tools for MIPS - MTI".
MaxHeadRoom
Joined Jul 18, 2013
30,784
Not sure if he has one on the ver4 yet, but I was also alluding to the later one Dave did on the 3 regarding the MPLAB IPE which Microchip brought out due to the feedback they got.
Max.
