How to run pickit 2 not working it is not detecting pic16f877a??
Bad USB cable?it is not communicating why?
Not all clones are created equal. That is why it is best to just buy the real thing. Plus no where does it way the device in the TS's link is a clone at all. It includes a software CD presumably with its own custom software.I've been using a Pickit 2 clone (purchased from an Asian vendor via eBay) for years, and within its limitations, it works fine. The limitations being that it won't work with newer devices. I hate MPlab, so I use the Pickit with freestanding software, which unfortunately Microchip no longer seems to have available. You can read about that situation here, and maybe get the software from a source outside Microchip:
http://www.microchip.com/forums/m775322.aspx#775345
Where would you think you could buy a Microchip product??You likely wasted rs. 1,100. Buy a real Pic Kit.
from where?
That just doesn't seem right... Buying tools from the chip manufacturer? Who does that?Where would you think you could buy a Microchip product??
http://www.microchip.com/developmenttools/productdetails.aspx?partno=pg164130
Click the big green BUY.IT.NOW button.
Links to free MPLABX there too.
No. One is a PICkit 2 and one is a PICkit 3. The PICkit3 is the only current PICkit from Microchip.is both programmer are same?
http://robokits.co.in/programmers/microchip-pic/pickit3-usb-pic-programmer-debugger
Both the same as what? The picture is of a Microchip PICkit 3. A PICkit 3 will program AND debug. You can buy a genuine one for Rs 3073 ($47.95 US) at:PICKIT3 USB PIC PROGRAMMER/DEBUGGER
robokits website say pickit 3 is both same??
Mod edit: stop shouting.
Well.... that depends on what you are going to be doing with it. One small difference is that the '877A has 40 pins and the '1503 has 14.16F1xxx
pic16f1503
this will be fine ?
| Thread starter | Similar threads | Forum | Replies | Date |
MPLAB® PICkit™ Basic In-Circuit Debugger | Microcontrollers | 2 | |
PIC18f4550 Programming by PICKIT 5 | Microcontrollers | 4 | |
Pickit 3 OK for 12F1822 ? | Microcontrollers | 1 | |
| A | pickit 4 error | Microcontrollers | 3 | |
| A | ICD 4 AND PICKIT 4 debugger | Microcontrollers | 2 |
