PIC18F45K22 and a EP50S 10-bit Gray Code Rotary Encoder
GettinBetter
Joined Jun 22, 2018
42
Hi peeps, I've got myself a EP50S 10 bit gray code encoder and was expecting it to only have two pulse connections, ignoring supplies (something like PH1 & PH2) however it has a cable for each of all 10 bits (I obviously downloaded the wrong data sheet when researching, but the resolution is correct)... so I was wondering if it is at all possible to poll the 8 pins of Port B and say 2 pins of Port A to create my 10 bit code and then convert to Binary or HEX (not sure yet). I should mention that some of Port C is being used for Terminal over EUSART, and PWM and hopefully Port D for reading a gyro (gulp).
Is the encoder suggestion doable and an acceptable approach, or am I barking up the wrong tree? Any comments gratefully received.
Regards
Les
joeyd999
Joined Jun 6, 2011
6,460
Here's some PIC18F 16 bit gray to bin code I wrote a long time ago in a galaxy far, far away. Maybe it'll help:
Code:
;** GRAY2BIN -- Convert ordered gray code to binary data **
;**   Input data: GRAY1:0                                **
;**   Output data: BIN1:0                 **
gray2bin
    movff    gray1,temp1        ;don't destroy gray
    movff    gray0,temp0
    clrf    bin1            ;clear binary
    clrf    bin0
    movlf    bitcnt,16        ;sixteen bits to convert
gloop    rlcf    temp0,f            ;rotate a bit out
    rlcf    temp1,f            ;into carry
    rlcf    temp2,w            ;roll bit into w.0
    xorwf    bin0,w            ;calculate new 1 or 0 in w.0
    movwf    temp2            ;save result
    rrcf    temp2,f            ;rotate new bit out
    rlcf    bin0,f            ;and into result
    rlcf    bin1,f
    djnz    bitcnt,gloop        ;do for all bits
    return                ;and get out
WBahn
Joined Mar 31, 2012
33,253
Regards
Les
What you were expecting (with the two phase outputs) is an incremental quadrature encoder. What you got appears to be an absolute position encoder that outputs the position in Gray code.
Assuming that it is a reflected Gray code (which it almost certainly is) then converting Gray to binary is very straight forward.
One way is the following (store the graycode in a 16-bit unsigned integer named v).
v ^= v >> 1;
v ^= v >> 2;
v ^= v >> 4;
v ^= v >> 8;
GettinBetter
Joined Jun 22, 2018
42
It sounds like it uses parallel connection. What you propose is doable.
Yes it does, in fact I did a search for parallel connections for the PIC, nothing of any significance came up, so I thought I'd ask directly.
Appreciate your help guys. Now to the fun bit :)
