Need help o code for PIC18F45K22 and 5 TPIC6C595D Shift Registers
Rob.duffy212
Joined Nov 1, 2023
Apologies if this is in the wrong section. Im writing code for PIC18F45K22 and 5 TPIC6C595D Shift Registers.
I need the shift registers to run through a sequence to turn on and off LED, one by one. Each bit has a corresponding LED.
The PIC is using the SPI function.
The first segment of my code seems to work ok. The first 16 bits are broken into 2 x 8 bit parts.
The first 16 LEDs will work as expected, but the LEDs belonging to the 3rd, 4th and 5th shift registers turn on and off sporadically.
Can someone please point out what im doing wrong.
C:
void SPIOut(unsigned int ind_value, unsigned char ctrl_value) {
    unsigned char first_byte, second_byte, third_byte, fourth_byte, fifth_byte;
    // Split the 16-bit ind_value into 5 bytes
    fifth_byte = (unsigned char)(ind_value >> 32);
    fourth_byte = (unsigned char)(ind_value >> 24);
    third_byte = (unsigned char)(ind_value >> 16);
    second_byte = (unsigned char)(ind_value >> 8);
    first_byte = (unsigned char)(ind_value >> 0);
    // Send the bytes through SPI
    SPI1_write(fifth_byte);  // Send to the first shift register
    SPI1_write(fourth_byte);  // Send to the second shift register
    SPI1_write(third_byte);   // Send to the third shift register
    SPI1_write(second_byte);  // Send to the fourth shift register
    SPI1_write(first_byte);  // Send to the first shift register
    // Now it's time to pull the latch to transfer the values from the storage register to the value register
    LATC4_bit = 0;
    asm { nop };
    asm { nop };
    asm { nop };
    LATC4_bit = 1;
    // Send the last byte to the fifth shift register
    SPI1_write(ctrl_value);
unsigned int led_state;
int i;
//unsigned char bytes [5];     // Array to hold data for 5 shift registers
void main() {
        // 16MHz Speed
      OSCCON.IRCF0=1;
      OSCCON.IRCF1=1;
      OSCCON.IRCF2=1;
      PLLEN_bit = 0; //Disable PLL
  ANSELA = 0;                                    // Configure PORTA pins as digital
  ANSELB = 0;                                    // Configure PORTB pins as digital
  ANSELC = 0;                                    // Configure PORTC pins as digital
  ANSELD = 0;                                    // Configure PORTD pins as digital
  ANSELE = 0;                                    // Configure PORTE pins as digital
  TRISA = 0b11111111;  // PORTA All Inputs
  TRISB = 0b11111111;  // PORTB All Inputs
  TRISC = 0b00000000;  // PORTC All Outputs / UART
  TRISD = 0b11111111;  // PORTD All Inputs
  TRISE = 0b000;       // PORTE All Outputs
  LATC = 0x00;                                   // Initial PORTC value
  LATD = 0x00;                                   // Initial PORTD value
  LATC0_bit = 0;                  //clear latch
       asm{nop};
       asm{nop};
       asm{nop};
  LATC0_bit = 1;
  led_state = 0x0001;   // initial value which we will send
  SPI1_Init();
  Delay_ms(50);
  LATC4_bit = 0;
  TRISC4_bit = 0;                     //Use SPI in line as output for RCK
    LATC4_bit = 0;
  do{
  for(i=0;i<32;i++) {
       led_state = led_state << 0x01;
       SPIOut(led_state,0x00);
       delay_ms(300);
} while(1);
Mod edit: code tags - JohnInTX
C:
What happens when you shift a 16-bit value 16 times or more in a 16-bit variable?
https://en.wikipedia.org/wiki/Bitwise_operations_in_C
RIGHT
However, do note that a shift operand value which is either a negative number or is greater than or equal to the total number of bits in this value results in undefined behavior. For example, when shifting a 32 bit unsigned integer, a shift amount of 32 or higher would be undefined.
LEFT
However, do note that a shift operand value which is either a negative number or is greater than or equal to the total number of bits in this value results in undefined behavior. This is defined in the standard at ISO 9899:2011 6.5.7 Bit-wise shift operators. For example, when shifting a 32 bit unsigned integer, a shift amount of 32 or higher would be undefined.
