Google is your friend...http://www.8051projects.net/lofiversion/t50417/16x2-lcd-16f877a.html
Did you click the blue & underlined text from my previous post? This is a link. When clicked it will take you to a website that I found, in which, it describes connecting a LCD to a PIC16f877A...please i need to solve this problem if you can help me or tell from where i have to start
That's because you don't have the library the main program is referencing.http://www.8051projects.net/lofivers...d-16f877a.html
i do exactly the same connection here and the same code but stil not working
That changes the contrast to the LCD...as i read i have to change the variable resistor until i see the lcd working is it right?
Either find one that works, or write your own...It's probably easier to write your own...so , how i will have this library?
See post # 31so , how i will have this library?
To interface to the LCDtell me please this library for what?
It's the same interface. The way you define and interface to it may be slightly different, (HiTech vs. mikroC), but the same technique applies. This tutorial goes step-by-step into what you need to do...but i am using mikroC compiler
Thread starter | Similar threads | Forum | Replies | Date |
P | How ADC value stores inside ADRESH and ADRESL register for pic16f877a .. #2 | Microcontrollers | 1 | |
microcontroller pic16f877a | Homework Help | 1 | ||
T | ARDUINO CODE TO PIC16F877A CODE | Microcontrollers | 1 | |
A | variable delay in PIC16F877A | Microcontrollers | 5 | |
Hx711 interfacing with PIC16F877A | Microcontrollers | 2 |
