If you touch it momentarily to ground it resets the PIC - that's it's purpose so it won't do any harm.i'll connect the MCLR pin of the pic to the ground sir? what will happen sir? it wont damage my pic? thank you!!
Usually, you pull MCLR to Vdd/Vcc using a 10k resistor - particularly if you are using an ICSP programmer.Looks fine. Is MCLR pulled up to Vdd (preferably with a resistor)?
Post your code & schematic.hmmm..i thought it will do the trick.. do you have any idea sir if how can i solve this starting up problem thing?
Thread starter | Similar threads | Forum | Replies | Date |
P | How ADC value stores inside ADRESH and ADRESL register for pic16f877a .. #2 | Microcontrollers | 1 | |
microcontroller pic16f877a | Homework Help | 1 | ||
T | ARDUINO CODE TO PIC16F877A CODE | Microcontrollers | 1 | |
A | variable delay in PIC16F877A | Microcontrollers | 5 | |
Hx711 interfacing with PIC16F877A | Microcontrollers | 2 |
