OSCCAL only fine tunes the internal oscillator. You need first to select it in the configuration word. See attached pdf.i set OSCCAL = 0b11111100; for internal 4MHz
in programmer software i set config register to 3ff4 but it work same as beforeOSCCAL only fine tunes the internal oscillator. You need first to select it in the configuration word. See attached pdf.
John
and you know how choose library in mikroc version 7?OSCCAL only fine tunes the internal oscillator. You need first to select it in the configuration word. See attached pdf.
John
John
i set osccal in mikroc OSCCAL = 0b11111100; and configuration in programmer software is 01F4 for 4MHZ internal oscilatorI see that, but you have set a 16-bit value for OSCCAL (3FF4). The largest allowed value for that register is 0xFC. Try the center value of 0x80.
You can check program memory for what was actually placed in the register. On that chip it is at 0x90 (Bank1)
John
I don't know. But it is said that a sane person would not keep trying the same thing that didn't work. I suggested changing OSCCAL to a more typical setting. jayantha suggested setting up a new project as sometimes that fixes a flaw.i set osccal in mikroc OSCCAL = 0b11111100; and configuration in programmer software is 01F4 for 4MHZ internal oscilator
whats wrong with this settings?
by Aaron Carman
by Aaron Carman
by Aaron Carman
