PIC16F676 <= Why does this program not work? ..#2
John P
Joined Oct 14, 2008
2,068
What does your program do, and have you read the data sheet section 9.2.5.1?
The PIC16F676 is an obsolete part, anyway. You'd do better to switch to something more modern. Microchip says "Newer device available PIC16F18324".
Ian Rogers
Joined Dec 12, 2012
1,136
The OSCCAL is normally at 0x3FF and can only be fetched.. If it is missing you have to re-cal the figure with pickit 2.
then in XC8 you use OSCCAL = __osccal_val();
No Idea in Mikro C
On the web folk are using asm.
Code:
asm
bsf STATUS, RP0 ';Bank 1
call 0x3FF ';Get the cal value
movwf OSCCAL ';Calibrate
bcf STATUS, RP0 ';Bank 0
end asm
There was an issue with finding the OSCCAL reference in MikroC so just make it known by putting a line in your codebefore the asm routine
OSCCAL =OSCCAL;
