PIC programmer/development
Jassper
Joined Sep 24, 2008
103
I'm looking for a good PIC programmer/development board.
One I have located is very cheap, but requires assembly (no problem there) the other is very expensive.
Cheap http://www.apogeekits.com/pic_lab.htm
Expensive http://www.ccsinfo.com/product_info.php?products_id=16F887kit
Is the cheap one too cheap and is the expensive one worth the money? I know the higher cost one comes with a bit more stuff.
This is what I am working on, I need to read voltage levels between 0.4 volts and 5.0 volts, and communicate this info via RS-232 I need at least 4 Analog ports.
Are these kits any benefit, or can you recommend a different approach?
Jassper
Joined Sep 24, 2008
103
Let me ask this a different way,
What "Getting Started Kit" for Micro controller do any of you recommend that will cover analog ports and RS-232, and what Micros have at least 4 analog inputs?
FastEddie
Joined Jul 14, 2007
35
I'm not sure if this is what you're looking for but I got one of these about 3 or 4 months ago. http://www.mikroe.com/en/offer/I got the Basic version but you can also get it in C and Pascal. It's easy enough to use. I haven't tried the rs-232 yet. The only downside I had was that since it ships from overseas it took a long time to receive it.
Jassper
Joined Sep 24, 2008
103
Hay thanks for the link, those look like some very nice boards and they come with with everything needed. I'll check them out further.
