Hello!
MPLABX, PIC18F16Q40, I2C, MLX90614 sensor.
To get the correct result from the sensor, a Repeated Start required in the communication sequence. Whith this new type of I2C module, i don't know how to do that. Attached the read code which is using Stop and Start instead of Repeated Start. Without the correct communication i got only 0xFFFF.
Can somebody tell me, how to modify the code?
See picture, what is the difference between the good (PIC18F14K22) and the not good communication.
Thank you!
Thank you!
C:
extern volatile uint8_t mlx_msb, mlx_lsb;
static inline void wait4stop(void) {
while (!I2C1PIRbits.PCIF);
I2C1PIRbits.PCIF = 0;
I2C1PIRbits.SCIF = 0;
I2C1STAT1bits.CLRBF = 1;
void read_mlx(void) {
I2C1CNTH = 0;
I2C1TXB = 0xB4; //write address
I2C1CNTL = 1;
I2C1CON0bits.S = 1;
while (!I2C1STAT1bits.TXBE);
I2C1TXB = 0x07; //RAM Tobj1
wait4stop();
I2C1TXB = 0xB5; //read address
I2C1CNTL = 0;
I2C1CON0bits.RSEN = 1;
I2C1CON0bits.S = 1;
while (!I2C1CON0bits.MDR);
I2C1CNTL = 2;
I2C1CON0bits.S = 1;
I2C1CON0bits.RSEN = 0;
while (!I2C1STAT1bits.RXBF);
mlx_lsb = I2C1RXB; //LSB
mlx_msb = I2C1RXB; //MSB
wait4stop();
