Hello All
I would like to do some graphics on a PIC. I have done the HD44780 LCD but I would like to advance and do some proper graphics.
I know there is a development board PICTAIL which can do this, but it really is expensive and I was hoping for something a bit smaller.
I want to design the board layout from scratch and would buy the graphics controller chipset and then include it on the new design board.
I am sure this is possible, just not so sure as to how easy it is.
I believe I can use PIC GDD X, but I do not know if it is only for 32bit Pic's or 16 bit Pic's as well?
I was thinking a PIC24 or PIC dsp should be able to handle it?
I downloaded the PIC MLA and installed it.
It does not need to be super high graphics, but a 256 or 16bit color would be nice and there will probably be a 2bit GLCD application as well.
So.... :
1)Am I on the right track? Can you guys give me any pointers as to what PIC would be a good choice for this application?
2) What is a common Graphics Controller?
3) What Color Graphics Screen can I get (Ebay sells the one that is compatible with Arduino for relative cheap price),
sure this must be able to work with PIC as well.
4) Later on I will also like to include bluetooth, or Wifi to integrate with Android. This can be an external module as well, I don't mind.
5) Can I use the GDDX application?
6) Is there any external hardware needed to run a 2bit GLCD or will a PIC alone be able to handle that?
The main thing is I am sure that there is already existing libraries out there that can do this and simplify the coding greatly.
That would be first prize.
Using MPlabX with XCxx compiler at the moment.
Thanks
So.... :
Thanks
