i bought some new pic 12f508 chips for a project and found that i could not output on pin 2 , i have looked on various forums and tried all the answers i could find but none worked , i have included the program so you can see what i have and tell me where i went wrong please .
Moderators note : used code tags
Code:
; GP2 Test program
list p=112f508
#include p12f508.inc
__CONFIG 0X0FEA
ORG 0
MOVWF OSCCAL
OPTION 0XDF ;11011111
;Note: If the T0CS bit is set to ‘1’, it will override
;the TRIS function on the T0CKI pin.
;bit 5 T0CS: Timer0 Clock Source Select bit
;1 = Transition on T0CKI pin (overrides TRIS on the T0CKI pin)
;0 = Transition on internal instruction cycle clock, FOSC/4
;5.3 TRIS Registers
;The Output Driver Control register is loaded with the
;contents of the W register by executing the TRIS f
;instruction. A ‘1’ from a TRIS register bit puts the corresponding
;output driver in a High-Impedance mode. A
;‘0’ puts the contents of the output data latch on the
;selected pins, enabling the output buffer. The exceptions
;are RB3/GP3, which is input only and the T0CKI
;pin, which may be controlled by the OPTION register.
;See Register 4-3 and Register 4-4.
SETUP MOVLW 0XC0 ;set all 6 bits as output even 3 in only pin
TRIS GPIO
CLRF GPIO
MOVLW 0X00
MOVWF 0X18
NEXT MOVF 0X18,W
INCF 0X18,F
MOVWF GPIO
; BSF GPIO,2 ;to try direct control of port bit
CALL DELAY
; BCF GPIO,2 ;to try direct control of port bit
GOTO NEXT
DELAY MOVLW 0X01 ;LONG TIME COUNT (7)
MOVWF 0X15
T0 MOVLW 0X80 ;MED TIME COUNT (00)
MOVWF 0X16
T1 MOVLW 0X00 ;SHORT TIME COUNT (00)
MOVWF 0X17
T2 DECFSZ 0X17,F
GOTO T2
DECFSZ 0X16,F
GOTO T1
DECFSZ 0X15,F
GOTO T0
RETLW 0
END
