yes, its definitely 10K.Does the 10K resistor supplying the phototransistor actually measure 10K?
Depends upon exactly how you connect the diode, which wasn't clear in your post,@crutschow please tell if there is anything wrong with the diode idea, I just need to understand.
As I stated, that's a no-no.his is what I intend
If you place a piece of card between the emitter and detector, so blocking the IR beam, does the transistor still fail after it has been running for some time even with it blanked off?I have taken the emitter and photo-transistor apart and set them in a way that they are continuously facing each othe
We don’t know for sure. You have to try different things.Ok, thanks. Few more questions.
1. Would a 1uF with 1K be a good idea?
2. Need I replace all the caps in the circuit (especially the last one. Btw, that last one needs a series resistor too, right? Just for excess of caution?) or just the first one?
3. Are we dead sure its this cap to blame for the dying transistor? I'd like it if I don't have to wait another few days/weeks to be sure there was no other problem.
Please translate this for me. What is awful about it? Are we getting an insight into what is causing the transistor kill?Hi John, @JohnSnow16041992
This LTSpice simulation shows the response of your amplifier sections.
The final response at o5 is awful.
Also, the overall Gain is -18db !
E
EView attachment 304362
Hi Ericc, I really can't see how the application is relevant. I am telling you with surety that it is the photo transistor going bad. I have been doing this for some time now, replacing my photo transistors each time it goes bad. The new ones functions well as expected for a few days before the output goes bad again (expected signal amplitudes weaken, some noise comes in, delay in reaction is also seen) and I have to replace it with another new piece and voila it works fine again (for a few days). I'll try changing the cap and placing the current limiting resistor this time.Hi John,
It would help us, if you described what and how the project is required to detect the object.
E
could it just be a quality issue?If you are using this to detect an object between the LED and the detector, the circuit is ridiculously complicated. The photo transistor would put out a valid logic signal with no additional components! The resistor might need adjustment to get the right levels.
I don’t buy the capacitor discharge theory. The datasheet shows only milliamp level currents with Vce of 5V. And reverse (Vec) of 5V is right at the max allowed so I can’t see it destroying the transistor. The 10K would protect from all but the most egregious power supply glitch. So I think there must be something going on the we don’t know about.
| R | Well weeks going well. | Off-Topic | 5 | |
What is going on with LED circuit? | General Electronics Chat | 6 | |
| U | Blink camera power dilema, going crazy here. | General Electronics Chat | 32 |
