Photomultiplier amplifier circuit
Alvin_freeman
Joined Sep 23, 2022
35
I add R8 for making a negative signal, and I add 1/2VCC because author of circuit in the first post add too.( sorry I am not electronic engineer.) So I can make mistakes. I am learning
sghioto
Joined Dec 31, 2017
8,737
You don't seem to understand what I'm saying. R8 should be 50 ohms and there should not be a connection from the cathode of D2 to the 1/2 Vcc junction of R6-R7.
Alvin_freeman
Joined Sep 23, 2022
35
Okay, did you see first had drawn schematic. I have a question why he add 1/2 VCC to the cathode of photodiode. Why R8 should be 50 ohms? There is no r8 in the original schematic I add it to schematic.
sghioto
Joined Dec 31, 2017
8,737
The data sheet for D2 shows using a 50 ohm resistor where you added R8. Adding R8 is fine but try changing the value to 50 ohms in the simulation.
Looking at the first drawing there should not be a connection from the cathode of D2 to the 1/2 Vcc. I don't know why he showed that.
In your schematic in post #19 you should remove the connection from the cathode of D2 to the junction of R6-R7.
35,017
If you are going to do the simulation start off with using a bipolar supply and bipolar opamp just to get things working. We can modify the circuit at a later time.
Alvin_freeman
Joined Sep 23, 2022
35
I did what you said before, removing or adding R8 or connection you said before didn't change anything.
Alvin_freeman
Joined Sep 23, 2022
35
If you are going to do the simulation start of with using a bipolar supply and bipolar opamp just to get things working. We can modify the circuit at a later time.
I will try bipolar supply but I don't know my Opamp is bipolar or not there is no information about it. maybe all are unipolar!!!
35,017
If you select a generic opamp from the library and there are 5 pins with two showing Vcc+ and Vcc- or V+ and V- then it is bipolar.
Select a FET input opamp such as TL071.
Alvin_freeman
Joined Sep 23, 2022
35
I didn't find VCC in my simulator, but I add bipolar power supply and TL071. this time I get different signal shape but I don't know which one was correct. Square waves? which I get before or Sine wave.
35,017
I am not at a desktop PC and can only enter posts via an iPad.
You do not need a sinewave or fullwave rectifier circuit.
Connect V+ and V- supplies directly to the opamp.
Remove the Si diode. You will simulate the detector signal with a short duration positive or negative pulse as I introduced in post #17.
Alvin_freeman
Joined Sep 23, 2022
35
You mean I must remove all rectifier diodes and put AC voltage directly to the Opamp?! I did it. and I add an VPULSE generator.
sghioto
Joined Dec 31, 2017
8,737
I think this is what MrChips was suggesting.
In this circuit I'm using a LM2904 you had in your previous circuit. The LM2904 is a dual op amp and by connecting the signal to the positive input will only require 2 stages. Notice the polarity of the 9 volt batteries on pins 4 and 8. U1A is set for a gain of 101 followed by the filter/buffer U1B
sghioto
Joined Dec 31, 2017
8,737
I agree with MrChips based on the input waveform. The problem is trying to simulate what the output from the actual sensor should look like in my opinion.
Alvin_freeman
Joined Sep 23, 2022
35
Those results are actually promising.
Why do you say something is wrong?
I don't know but I tried to put a negative small pulse like real pulse and I expect an positive wide pulse on the output. I think small changes on input pulse maybe affect hugely output.
