Photo interrupter advice needed
Phil Russell
Joined Dec 21, 2014
19
Hello, I wonder if someone can offer advice regarding a photo interrupter:
It is part of a small circuit board on a mini lathe that provides a spindle speed readout. The component has the following codes: H12A5 ICI on the circuit board near the component and GK 105 moulded on the component itself. The gap is 5mm (as far as I can measure) and the component is a 4 pin one.
I have been trying to find a replacement for this component but despite trawling the web have found no information. I am no electronics expert so can provide no data on voltages etc, sorry.
Is there a list of 'equivalents' anywhere that would allow me to get a replacement component to fit? I am quite able to remove / replace components on a board. Why do I need a new component? I suspect the old one has broken as the casing seems loose on the pins.
All help would be appreciated.
Regards
Phil
Phil Russell
Joined Dec 21, 2014
19
There are several out there, search for Slot Opto, https://www.digikey.com/products/en...ointerrupters-slot-type-transistor-output/548
TCST1103 eg.
Max.
Hi Max, thank you for your response, it is appreciated. But I am confused.
Are you saying that a TCST1103 will be a direct replacement for the H12A5?
I looked up the 1103 and it says '3.1'mm which I assume is the gap between the component arms? If so, the H12A5 has about a 5mm gap and I would be concerned that the 3.1mm is a tad too narrow for the spinning disc on the rotating spindle.
Sorry for being so ignorant but I am not an electronics expert.
Cheers, Phil
28,139
Cheers, Phil
I suggest visiting the NEWARK electronics website, and also the DIGIKEY websites and looking at interrupters in the optical devices section. What that will do is give you a bit of information about what variables are specified and how the devices are described. You may not find a suitable replacement, although there are a lot of different beam interruption devices on those sites. I am suggesting them primarily for the educational value. Cheap and easy learning in a convenient format.
Phil Russell
Joined Dec 21, 2014
19
For 5mm slot the Digikey link I sent shows OR518 or OR627.
Just for a couple.
Max.
Once again, thank you Max for your patience. I am now wondering if I have been looking too hard and maybe if I match all the physical characteristics e.g. gap width, pin spacing etc I might get a decent match. Certainly the ones you just mentioned look the same in the picture. I have no idea of the voltages present etc but guess it is worth a try ...
Once again, thank you all for your help, I appreciate being educated.
Cheers, Phil
MaxHeadRoom
Joined Jul 18, 2013
30,791
They are not usually all that different between types and unless there are significant problems, the slot width doesn't usually make alot of difference.
Post the one you are thinking of subbing and we can check for any significant differences.
There is normally a resistor for the LED, typically 100 ohms and a pull up resistor on the transistor output, 10K typical.
Max.
Phil Russell
Joined Dec 21, 2014
19
Max.
Update and Thank You.
Thank you all for your advice and apologies for taking so long to reply. I accumulated all necessary bits including an OR 518 (aka EE-SX1042) and built up the new circuit (if I can call it that) this afternoon. Hey presto ... all working as it should.
So ... many thanks for the help and advice you all gave. I have learnt a lot about these little components while doing this and am very pleased that I sought your help.
Kind regards
Phil
