TS427 collector -143mV and with SK15 Wind pressed -94mV
TS427 base -0.75v and with SK15 Wind pressed -0.69vPower on the recorder but don't press any of the buttons. measure the base and collector voltages of TS427 and TS429 with respect to ground and make a note of them.(This is relating to the slide solenoid not working.)
IC455 Pin 1. (centre) -11.20vMeasure the voltages on pins 2 and 3 of IC455 with respect to ground and make a note of them. (This is relating to the reel motor not working.) Press and release the wind button. Repeat the above measurements.
The solenoid relay RE476 (circled G65, G66, voltages, grey +96mV, Red 120mV and rising); if you look at the photos, you can see it would push the connecting cam and bring in to motion some of the surrounding gears, this is for play, for fast forward I think the cam moves and brings in other gears in to motion and also the notched black wheel you can see in the other photo which tells the inferred (detecting) unit that there is motion, and allow the buttons to stay active/set. When it was working; the buttons stayed set and when the cassette came to an end it would switch from play to stop.I have not really thought what the function of the slide solenoid is up till now. I think it may be to lock the buttons in the down position until the stop button is pressed. When it was working did the buttons stay down when they were pressed but now do they spring back up again ?
Les.
I am guessing that the inferred (detecting) unit detects that there is motion and allows the buttons to function, because there is movement. If I remember correctly; once you insert a cassette this top slide solenoid is activated straightaway, this is part of the problem.As you say that the buttons remained in the pressed position when the unit was working what mechanism held them in the pressed position ?
Yes I did manually move the slide solenoid across and press play; tape just came out of the cassette, I suspect the capstan motor just pulled it through. It isn’t fast.I suspected it would be the slide solenoid.
Can you manually operate the slide solenoid ? This is to check if it is sticking.
I had fitted new transistors to boards U301 and U302; after refitting and testing these; motor 2 that turns the gears does not work.When you caused the fault what were you doing ? What was it that was wrong before you caused this fault ? This may give a clue to what may be wrong.
TS427 collector to ground -143mV then I used a Through Hole Trimming Potentiometer set at 1k and made an additional connection between base and ground via this resistor, this now alters the reading to -9.2vCan you monitor the voltage on the collector of TS427 with respect to ground and connect it's base to ground via a resistor of about 1K . The voltage should change from about zero volts to about -11 volts.
Can you check the voltages on the collectors of TS451 and TS452 with respect to ground both without the wind button pressed and with it held in the pressed position ?
You were quite right and not only TS452, also TS450, I bought 5 of these and they are all open circuit between base and collector maybe the damage could of been worse if they had been good?I think transistor TS452 has an open circuit base emitter junction. If you still have the original transistor you could try refitting it. (My understanding is that you replaced them even though there was nothing wrong with them,)
Correct.When you say the bottom solenoid do you mean the Slide or the pressure roller one ?
The solenoid that is working is the Electromagnet Pressure Roller RE475You have not answered the question "When you say the bottom solenoid do you mean the Slide or the pressure roller one ?" Is it the slide solenoid ? Or is it the pressure roller solenoid ?
This is the information I came up with for TS450 and TS452, they are both the same type a BC636, I came across a very useful website that has identified all the transistors for this unit, I am sure you know it very well.If you bought the transistors from Farnell I think it is very unlikely that they are faulty. I have checked data sheets for the BC636 from several manufacturers and they all show the same pinout as the Fairchild datesheet downloaded from Farnell. I had a look at the layout diagram for the motor control board (Fig 24) and the pinout labeling for the BC636s is wrong. NOTE the view in Fig 24 is from the copper side of the board. If the connections on the BC636s that you have match the data sheet then you should not have to cross over any connections. NOTE the base is NOT the middle pin. It is pin 3.
by Aaron Carman
by Duane Benson
by Jake Hertz
