Phase cut two mosfet dimmer
subhamay
Joined Jun 21, 2023
How to work phase cut two mosfet dimmer? I need current flow direction, waveforms .Please answering the question or suggest the study material where I will get.?
LowQCab
Joined Nov 6, 2012
5,102
The first thing that You will need is a completely isolated FET-Driver.
This will not work for high-frequencies.
AC Switch 1 .png.
LowQCab
Joined Nov 6, 2012
5,102
When the Gate-Voltage is generated by the "Photovoltaic" FET-Driver
both FETs will turn On simultaneously.
Then You need to Power the LED with standard Phase-Chopper Circuitry,
similar to that used with a Triac-Lamp-Dimmer, or Motor-Speed-Control.
You can also use LOW-FREQUENCY PWM Chopping, ( ~200hz max ).
This is because this type of FET-Driver is very "slow" compared to standard FET-Drivers.
