Please bear with me on this question which has stretched my ageing analogue mind.
I'm building a pendulum clock. One swing - say, left to right -(t) takes 1 sec and the "period" (2t) - start position back to the same position takes 2 seconds.
It's in an early stage and the pendulum is not yet driven - but will swing freely for a while.
For mechanical reasons I need to get the pendulum adjusted to be be as nearly timed as possible - ie before it can be rated as a clock over several hours.
The pendulum is sensed by opto-interupters. At present I have just one which happens to be at about the centre of the swing (but I don't think it matters where it is). The timing width of the pulse from it is about 200 milliseconds but the width varies a bit depending on the amplitude of the swing (and hence its speed )
My only method of measuring the measuring (t), or (2t) is with a Racal-Dana 9904 counter/timer in "stopwatch" mode. This can start and stop a count by selecting edge polarities. It will easily measure the opto pulse width but that's no good to me.
My attempts at a timing diagram are confounded by the fact that a +ve edge is a -ve edge on the next pass as the pendulum is traveling the other way.
If you are still reading this - thank you
So, the question is how can I accurately measure (t) or (2t) As far as I can work it out I will need a dual "D" type flip flop (4013) set to divide by 4 and measure one positive or negative going output pulse.
Confirmation, or other suggestions please !
I'm asking because, after an accident, the opto has failed and a replacement will take 2 weeks from China..
Thanks in advance.
Thanks in advance.
