Peltier project suggestions/ideas/corrections
wayneh
Joined Sep 9, 2010
18,155
But how it supposed to go from 12V to 15.7V for the Peltier
The 15.7V rating is the maximum voltage for the module, not it's recommended operating voltage. You don't want to get near it. To approach that voltage would require a very effective heat sink to dissipate all the heat being produced. It's also possible that heat is not the only issue and that voltage alone might damage the internal junctions of the device - I'm not sure.
inOr
Joined May 31, 2017
Given that your controller is 'smart', you don't need an electronic PID controller. In your case, PID is an algorithm for sensing temperature changes and responding with bursts of current calculated to approach as quickly as possible while avoiding too much overshoot and oscillation. The magnitude of these current changes will be computed in the RPi according to the PID algorithm.
