Need Suggestions for my project
Adi999xx
Joined Jul 29, 2023
I have an adjustable power supply of 150W.I want to power two peltier modules of 12v/6amps and 12v/3amps and two fans each of 12v/0.72amps.
Please suggest me an efficient way to power all devices.
BobTPH
Joined Jun 5, 2013
11,678
Do the math. The boost board you show is limited to 6A. The devices you want to power add up to 10.44A.
Most efficient? Use a 12 V battery or power supply capable of at least 12A.
Hymie
Joined Mar 30, 2018
1,347
A 12Vdc supply capable of delivering 10A will be able to power all the devices.
What were you proposing as the input to the boost converter?
BobTPH
Joined Jun 5, 2013
11,678
It might, but you will be exceeding it’s max current spec. That why I suggest 12A, giving you a little margin.
28,593
You could put the 3 amp Peltier device in parallel with both fans and then put that in series with the 6 amp peltier device, and adjust the power supply voltage to deliver exactly 150 watts. BUT I do not advise that, unless the supply is rated to deliver rated power continually. That could be a "Mil Spec" rating, maybe.
