About the same time all the polar bears die off:The world is currently drowning in a glut of cheap oil.
Someone remind me, please: when's that "peak oil" supposed to happen?
Your example isn't nearly as funny as mine: "Scientists just found an unexpected factor that could be driving Greenland’s ice loss" from Washington Post - https://www.washingtonpost.com/news...or-that-could-be-driving-greenlands-ice-loss/About the same time all the polar bears die off:
Well lets hope I don't win the lottery because that's on theory I will bankroll and test myself.what if abiotic theory of oil creation is correct
Having thought about this more, I would say that it is ***definitely*** possible:As to whether oil could come from a non-biological process, I guess it is possible:
TC,Well lets hope I don't win the lottery because that's on theory I will bankroll and test myself.
After spending time in our local oil fields and talking with all the engineers and smart people who do the geo mapping to see whats under our feet I have very strong suspicions that where I live may very well be siting on a abiotic super formation about 8 miles below us.
It happened in 1970. Fracking changed everything. I'm not sure anyone has reformulated the theory.Someone remind me, please: when's that "peak oil" supposed to happen?
Not exactly being there are number of factors in the whats and how of drilling and maintaining a functional oil well.TC,
Could you tell where the price point was that made fracking to expensive?
Very interesting.Not exactly being there are number of factors in the whats and how of drilling and maintaining a functional oil well.
Around here a properly drilled and good producing well that did not have any major screw up in its drilling followed by a fracc job that also didn't have any major screw ups plus if the whole job was ran by someone who kept a tight leash on the general spending involved start to finish could very well be profitable down under $20 a BBL!
Given that the inside word here is the average on break even for the Bakken is around $25 - $30 per BBL with many well that could still run a profit under $15 a BBL.
The problem is when a well was drilled badly due to sloppy work, in experienced drilling crews, or cheap components having been put in followed by a fracc job that does not go well due to such things it is quite common to have wells that end up with high installation costs and low return rates which pushes their equivalent cost per BBL break even points way higher.
Right now where I am the primary limiting issue is simply that we still do not have an adequate infrastructure to get our cheap oil out to a refinery. The oil at the wellhead is cheap to produce but getting it to a refinery is what's hurting us.
I'm not sure what to think. What I do know is our infrastructure work in the state has not slowed down one bit so obviously the people at the top don't feel this dip in price is going to last all that long.I hear the Saudis have a trillion in the bank, not so sure about the others, but it could go on for some time. What are you hearing?
TFracking changed everything
Wow, well that's nice to know. At least maybe that shows a way out for our oil companies.In a way I don't really feel bad for many of the oil companies going bankrupt.
Most of them put themselves there by continuing to run like they had no end to their money knowing full well things could and likely would change at any time.
One thing I learned while working in the oil fields is by and large financial efficiency is not a commonly practiced concept despite the often times glaring need for it.
I have often looked at what I was seeing in our local oil fields and have thought that if even the most basic financial responsibility was practiced we could produce oil here at well under half our present average costs.
