KingWhiskers
- Joined Mar 2, 2021
- 18
I fixed it relatively easily, the board had a name on it OVC 1000 and I searched for that. Found the photos and enlarged them.As I mentioned, one eBayer I contacted that offered to repair these boards bulked and wrote back that he can't fix this board once he had seen the picture of it. I was just checking the options at the time, wasn't really going to use his services except as a last resort. So these repair services may or may not fix things and it is best to consult them with some pictures before you send them the board.
Lucky that you found and fixed an issue that was easy and no cost. Seems like you got a bargain of a steal.
So the board of your oven did go bad and you had to use another board from another oven that matched. Verify this if I am wrong about this conclusion please. How long did it take after you got the oven when the board went bad? From the experience I have gained from this oven that I am doing a re-cap job on, I would guess that your oven probably had an intermittent board just like this oven and the strand of the element getting caught into the insulation of the oven was not an issue at all and because of the intermittent nature of the oven's operation, it just came back after a while and then went dead again, making you think you had fixed something when you really had not. What do you think? Is this a likely scenario, or are you sure you fixed it the first time and then the board on it went bad? Let us know. Thanks.
Relay(s) could be bad on this board that I am working on, but because of the nature of its intermittent problem (going black screen for months and then coming back on its own and working for days or weeks) I tend to think this is something else, the capacitors in this case. If a relay contacts are blackened, mechanical force or vibration may jolt it into operation, neither of which was likely applied to this board as it sits high on the oven in the wall and no one would likely touch it or jolt it in anyway. This intermittent way devices fail seems to be one way capacitors go bad (possibly) in particular electrolytic capacitors.
How did you match your board to another board? Is there a number on the board itself that can be reference to find similar boards? Did you go by the picture of the board? Thanks.
Bought the first replacement and that worked. The old board was a 2004 vintage design, the new ones were a 2009 design and are still available. They were even available on the AEG spares web site when I last looked but on just checking no longer available. So yes I looked at numbers and checked the number of relays and shape of connectors on the board. They are compatible with 14 brands of oven.
The original board that was in the oven lasted about a year or so before it went bad permanently. It gave a bit of a warning and the main oven would not heat up or got stuck heating up and remained on.
Switching off the main power, leaving for a minute then switching it back on would reset it for a while. That is when I changed it over to the new board I had bought and then bought another as a spare.
The only issue that I though was that the lose single strand of wire could have caused was if the insulation was a bit damp it might have shorted out slightly and caused the error code to appear. It was rather close to the back panel.
I got a real bargain with that one.
