PCB Layout Software, what's currently good and free
SoftwareGuy
Joined Oct 29, 2013
29
Can anyone suggest a good free PCB layout tool for making simple 2 layer (2-sided) PCB's? I used Altium Designer for a couple of boards at work, but it's not available to me anymore and since it's for my hobby my boss won't spring for another license, so I'm in need of something for home. ;)
ErnieM
Joined Apr 24, 2011
8,415
My vote is also for Kicad. When doing some consulting work for a start-up (ie, no budget) I used it professionally to good results. I use it for my hobby work too. The gerber files output are universally accepted.
It is 100% free, open source, well supported, and a learning curve similar to most other products.
Stuntman
Joined Mar 28, 2011
222
For small one-off style boards, I still like expressPCB. Keep in mind, Express PCB has their own file structure so you have to buy the boards from them (which I have found to be a great deal). If you want gerbers to take to a board house later, you have to purchase them from ExpressPCB for the tune of $60.
All this is not meant to scare you. For prototype style boards, I use them extensively with excellent results. In terms of ease of use and simplicity, I rate them among the top, especially when using larger outline parts. That's not to say I haven't some of the nastier flavors of SMD's on it.
I believe they have some rudimentary schematic capture features (paired with the expressSCH software), but I have not used it. The expressSCH is also very handy for quick circuits.
ronv
Joined Nov 12, 2008
3,770
I also used express pcb for a long time, but then had a need for gerbers. I tried a bunch of them and the learning curve drove me nuts. :eek: I then found copper connection. It is almost the same as express pcb but you can upgrade it for $45 to make gerbers. I had trouble with the others making custom components, like connectors and stuff, but found it easy with the two mentioned.
Buying free PCBCAD software can turn out to be expensive !
You really need a full package with full design rule checking.
Design rule checking is vital to not end up with a batch of pcb's that need butchering to fix them or end up in the bin.
dl324
Joined Mar 30, 2015
18,405
Anyone that recommends Eagle has never used anything else.. :p
Its inferior to many other free/low cost PCB programs..
The problem with generalizations is...
I used a couple free programs (one was PCB Express or Express PCB, which I found lacking). Once I used Eagle, I found it could do everything I needed and haven't found any deficiencies that would warrant investing time in learning another (yet:rolleyes:).
nerdegutta
Joined Dec 15, 2009
2,689
I used KiCAD, and found it OK. I liked the 3D view feature. But the lack of components/libraries led me to Eagle. Eagle have all the stuff I need, and then some.
I'd recommend Eagle, even thou the learning curve can be pretty steep.
mcgyvr
Joined Oct 15, 2009
5,394
The absolute first thing you should learn in any PCB program before you do anything else is how to create your own components/parts (schematic symbol and land pattern)..
nerdegutta
Joined Dec 15, 2009
2,689
When I started with Eagle, all the components I needed was in the libraries, but after a few months using Eagle, I needed some custom parts. I find it easy to make my own parts in Eagle. Both schematic symbols and footprints.
I didn't use KiCAD long enough, so I do not know how to make custom parts. I've used Eagle for quite some time now, and I do not think I'm going to switch to another. I even bought a license for an earlier version. But when I went from 6-something to 7-something, the license file was not valid anymore. I sent an e-mail to the company I bought the license from, but they could not help me. I might buy another license, but for now I'm all good.
