I designed a pcb around the STM32WB55CE. The RF design is meant for the capabilities needed for 2.4GHz bluetooth. I looked at the available AN's and did my first shot with the design. Please keep in mind, that this is my first RF circuitry.
For the RF matching, I chose the IC provided by STM. As an antenna I thought I'd go with a ceramic one, because I want the pcb to be small and also reliable (as opposed to a pcb antenna).
For the PCB itself, it's a 4 layer stackup (see the attached pictures) with:
top layer(red) -> signals only
inner layer 1(yellow) -> ground plane
inner layer 2(orange) -> power plane
bottom layer(blue) -> ground + signaling
The area around the antenna that is suggested to be kept free of metal is the silkscreen on the pcb pictures. I made the metal free area a bit bigger though, just to be on the safe side.
I also read about via fencing, but wasn't sure if it's a hard neccesity.
In general the bluetooth should work only within 2-3 metres.
The signals that are broken out are all digital with 3 exceptions. PA10, PA11, and PA12 will be used for analog readings .
Any suggestions are appreciated
-8
-8
