PCB connector identify
Jammur
Joined Feb 19, 2024
8
Good evening everyone, I have this 5v led backlight panel, the connector pins have snapped and it’s came away, my questions are, can anyone identify this connector and where I could get them ? And the pad on the pcb looks separated so could I just drop some solder into those holes and add some wire ?
Thanks Jamie
If the connector pins on your 5V LED backlight panel have snapped, you can identify the connector type and find replacements online or at local electronics stores. For the separated pad on the PCB, try carefully soldering it by cleaning the area, applying flux, and using a fine-tip soldering iron. If the damage is extensive, consider adding wires by soldering them to the traces leading from the pads for a reliable connection. Exercise caution and precision during these repairs to avoid further damage. <snip>
Moderator edit: spam link deleted.
