Help me identify this connector
patrik.sockovic@terrawatt
Joined Sep 24, 2024
Its similar, but not 100% identical, to this russian connector: https://www.ebay.co.uk/itm/265348593765
What is the diameter of the shell in mm?
Thank you for your answer, but unfortunately I already looked at this connector, but its not a good fit, the "notch" on the connector is too far from the pins, and the cable that is supposed to go into it already has a tightening system (picture of cable added in this reply). The outer rim measures 35 mm in diameter, while the inner rim measures 22 mm.
Mod: Cleaned up your image.
Irving
Joined Jan 30, 2016
5,155
Agreed, its not the same. Yours definitely seems to be more akin to the Russian ones than the common European/US ones, having the middle rows of pins on a rectangular grid rather than staggered alternately by row, or in concentric circles.
