PCB common ground connection - what is the standard way to do it?
mhasan
Joined Sep 7, 2021
Hi guys,
I am a software engineer, trying to do some electronics hooby work.
I am trying to build a controller circuit with Teensy 4.1 board and trying to design a professional looking PCB for the project.
My circuit design is very simple, I want to connect most of the Teensy 4.1 pin to a 40 pin strip header connector.
From there I can connect other components (I.e. switched and potntiometers). the design dilemma I am having while trying to drawing the schemetic for this iny project is, how to connect the ground of the teensy board to all the sswitches?
all the switched and potentiometer get connected to a common ground pin, but I am not sure how to make this connection cleaner?
What is the best way to desing these kind of common ground connction, where the ground is shared with 30+ seperate components?
I am doing the drawing usinf EasyEDA.
Thanks,
M
jiggermole
Joined Jul 29, 2016
188
Also a hobbyist here. Usually I apply a ground plane to my bottom layer. Sometimes to both the top and bottom layer. I use EagleCAD and I just make a polygon covering the whole board on the layer you want and make it the GND signal.
mhasan
Joined Sep 7, 2021
Thanks.
35,172
Assuming that every switch and sensor requires two connections, one of which being GND, I would use a dual row IDC ribbon cable. All of the pins of one row are connected to GND so that the ribbon cable supplies a pair of wires that go to each switch.
For powered sensors, e.g. potentiometers, that need three connections, I would use single 3-pin IDC connectors.
For digital inputs, e.g. switches, connect the grounds back to digital ground or supply GND.
For analog inputs, e.g. potentiometers, connect the grounds back to analog ground at the ADC.
Not every application needs a ground plane. Depending on the application, frequency of operation, and sensitivity to noise, you may be able do avoid using a ground plane.
dl324
Joined Mar 30, 2015
18,465
If you don't have analog and digital circuits on the board or high currents involved, it's pretty much a don't care. Just make sure you have sufficient decoupling caps on any IC's.
If you have analog and digital circuitry on the same board, conventional wisdom is to connect the digital and analog grounds in one place. Currents involved also play a role.
35,172
When laying a PCB I avoid connecting pads in a line (daisy chain) as shown on pattern A.
I prefer to offset the trace from the pads as in pattern B. This allows you to be able to isolate a pin by cutting the connection to the pad in the event that you need to make some corrections or do some debugging.
