This shows the populated memory slots.
Based on the photo in post #22:My drive doesn't spin, at all! I took the cover off carefully and the heads are all parked as the should be, I've ordered a new one the same in the hope it's the motor driver on the PCB, I'll swap them as soon as I get it!
Cheers Geoff
Make sure both cables are plugged into the hard drive. One is a sata cable, the other is a power cable. Plug one end of the sata cable into the HDD.It will find the SSD and the optical drive plugged into the sata socket but not the hard drive, the hard drive won't spin up or make any noise?
One thing to check is the Sata mode setting in BIOS. It should be set to "AHCI".Hi,
Yes have verified all plugged in right, I've also been through to temporary boot menu, it lost usb, SSD and the optical drive as options, I tried the SSD but no joy.
I haven't had much time to put to it today, but have ordered a new hard drive (same model number etc) so as soon as I get that I'll connect it up, I assume it should at least show up even if it's blank?
At least that will narrow things down a bit?
I've done a bit of googling and it seems if I swap the PCBs of the new and old drive I may have to swap the bios chips too to get it to work?
Thanks again, Geoff
| M | Fluke 73 series 1 Multimeter repair | Technical Repair | 10 | |
MC2100ELS treadmill repair (3) | Technical Repair | 16 | |
| J | 12v Low / Off / High switch repair re-connections | Technical Repair | 2 | |
| A | Handuro inverter board repair help" | Technical Repair | 1 | |
The JBL L75ms Repair (2) | Technical Repair | 3 |
