Today for an odd reason I decided to go onto my PC Bios just to change some boot settings. I came across the Power Supply Voltage and these were the readings
3.3V: 3.35
5V: 5.775
12V: 24.732
Both the 12V and the 5V readings were in red (which caught my attention) and the 3.3 was in white (which meant it was normal). Do you guys recommend I should keep using my PC? or should I replace the PSU Asap. Also can it Damage any other parts of my PC? I dont know the exact PSU Model (Since I use a Pre-Built PC) but I do know that it is a 300W power supply. The Model of the PC is "Asus M32CD-CA018T"
3.3V: 3.35
5V: 5.775
12V: 24.732
