hi,
I have a simple circuit I'm trying to build. It's a 12V DC Motor (Stall current 20A) powered by 3 Lithium-Ion cells and switched on and off using an Arduino and a MOSFET (IRFZ34N). Datasheet here: https://www.infineon.com/dgdl/irfz34nspbf.pdf?fileId=5546d462533600a40153563b1a522202
I've attached a schematic I'm working on, and I have some questions about the passive components:
1. I have my pulldown resistor on the gate (R7) set at 1k. I've seen some online schematics with this as high as 10k, would it need to go that high?
2. I have a diode going from the negative output to the positive, but I wasn't sure what type of diode is needed here. I was thinking 1N4001, but I also have some Schotke diodes on hand (to be totally honest this is the one passive component I never understand).
3. Do you see any other passive components I need to add?
