Modelling slew rate using opamp internal structure modelled using only passive components
Ktttt
Joined Jul 6, 2024
I am under internship where my guide is asking to model slew rate and cmrr my making the internal structure of opamp isl70444. How can I enhance my three stage model of opamp for this modelling?
BobTPH
Joined Jun 5, 2013
11,644
I examined your code through my crystal ball and here is my recommendation:
Insert the following code after line 137 in module “OutputStage.c”;
if (abs((dV / dt)) > SlewRate)
dV = sign(dV) * SlewRate * dt;
