Passing a rectified signal through a [series] cap
eromlignod
Joined Dec 8, 2012
8
Guys:
I know if you pass a sine wave with a DC offset through a series capacitor that it will remove the DC offset and the sine wave will then be AC, centered around ground.
But if I pass, say, a half-wave rectified DC signal through a cap, what will I get? I realize its average voltage will be translated towards ground, but will the bottom of the wave remain flat or will it be distorted? Thanks.
Don
38,856
It will be flat if the capacitor is large enough for the load resistance, and the circuit is properly designed to discharge the capacitor at the bottom of the rectified signal.
What is the frequency of the rectified signal, and what is the load at the capacitor output?
38,856
Eric, note that there is no discharge path between the diode and the capacitor, so it will eventually charge up to the peak V1 voltage.
