Parts List for Constructing High Voltage Charger & Discharger
geriatricjerry
Joined Dec 8, 2017
5
I need to construct a simple high voltage circuit charging / discharging circuit, and a harness for connection. I need some help with parts and assembly. Here is a basic diagram:
Questions / concerns:
1) I have a spare PC ATX power supply that I can use for 12v. My voltmeter has an operating range of 9 - 12V DC, will this be okay or do I need to step it down?
2) I need connectors with covers for safe HV connection. Any ideas for specific parts? This is labeled “battery harness connection” in the diagram and should be something like this:
3) fuses & fuse holders: would Mouser #530-3AG1-R and Mouser #441-R364-GR be appropriate?
4) in order to accomplish the task explained below, I believe I just need the relay and a Zener diode. Would Mouser #512-1N4742A and #653-G5V-1-T90-DC12 be appropriate?
Thank you for any assistance.
wayneh
Joined Sep 9, 2010
18,180
I don't think I can help you much but I recommend changing your drawing to eliminate the negative voltages. I believe you really mean ground for all of those. Putting a label of -12V or -200V on a schematic implies that these are voltages established below ground or some other zero-voltage reference point. In other words it's a much more complex circuit. And also there's no such thing as "+" and "-" AC, it's just AC. Use a "~" if you must.
Hopefully you'll get more feedback when your schematic is easier to follow.
Other minor things:
• I'd consider putting the mains power fuse before, rather than after the switch. It depends a little how your build is constructed but why not?
• What is the purpose of the DC-DC converter?
• Are you certain the transformer has an integral rectifier to produce DC output?
geriatricjerry
Joined Dec 8, 2017
5
Other minor things:
It's actually not my schematic. I'm going off info sourced from the web from others who have constructed similar circuits, but I wanted to double check everything here to make sure I understand everything I am doing given the safety risks of high voltage electricity.
I will transpose the switch and fuse.
I believe the DC-DC convert was only for voltage regulation for the voltmeter. I'm not sure if it's necessary or not.
I don't know about the transformer inside it, but my PC ATX power supply powers a 12v DC fan just fine.
Thank you so much for your help!!
