Thanks manThat looks like a Molex 11084 style connector. There are a lot of very similar appearing connectors. If you can find the exact one, then replacing the locking lever may be possible.
You need to examine it very carefully for details. For example,in the one shown above, the attachment feet extend very slightly past the housing. It can be soldered by had relatively easily. On many versions, the feet are hidden or only exposed on the outside, but do not extend past it. Then there are the hinges, and so forth. Measurements will be essential. Yours looks like it might be 0.5 mm spacing, but there are others.
Finally, if you do find an identical version, can you swap hinges without breaking anything.
My advice, find what you think is identical. Buy two. Try the latch from one. If that fails, replace the whole socket with the one left over.
