Hi,to everybody, i am using this circuit in the picture
The main problem is related to the two resistors R3 and R4 (to balance the two outputs), because since the maximum current is 15A, i have a voltage drop across the resistor (15A*0.01OHM), so the load regulation will be reduced. I already tried to put the feedback resistor (r1 and r2) after r4 but nothing change. Do you have some idea on how to solve the problem?
