Using Linear Voltage Regulator In Parallel With Two Different Voltage Outputs
Harsh_21
Joined Sep 23, 2021
12
Hello Everyone,
I am using a two LM317 in parallel with the same source and one LM317 should give 12v and other is 5v as a output voltage . But i am not getting the perfect output as i want. The LM317 which is for the 5v output is getting perfect output . But the the other LM317 is not getting the 12v as a output.
I am driving a controller with 5v . And 12v is further going to the my circuit .
vu2nan
Joined Sep 11, 2014
357
The LM317 requires an input-to-output differential voltage greater than 3 V, for proper functioning.
That would mean an input voltage greater than 15 V for 12 V output.
Nandu.
vu2nan
Joined Sep 11, 2014
357
The formula is V = 1.25 ( 1 + R2 / R1).
That would be 12.7 V with R1 = 240 Ω and R2 = 2.2 kΩ.
Nandu.
Harsh_21
Joined Sep 23, 2021
12
240 Ω and 2.2 kΩ would give 12.7 V.
Nandu.
But I want the 12v So that's giving me when tried single.
I want to know what if i give the 13v input to the LM317 for output of 12v . What should it give 12v or something lesser then 12v.
ericgibbs
Joined Jan 29, 2010
21,573
hi,
As vu2nan posted:
So Vin must be a minimum of 15Vdc for a 12Voutput
The 500R resistors should be 240R as specified in the datasheet for the LM317.
E
Harsh_21
Joined Sep 23, 2021
12
Actully the problem with the thing is that my DC voltage source is ranging from 25 to 12v And i want these two output of 12v and 5v continuosly . Can help me out with this??
BobTPH
Joined Jun 5, 2013
11,655
The 25V is too high unless you are using very low current, and the 12V is too low.
At 1A, the 5V regulator would dissipate 20W. And at 12V, the 12V regulator would not regulate.
You would be better off with two DC to DC converters. A buck for 5V, and a buck boost for 12V.
Bob
Harsh_21
Joined Sep 23, 2021
12
You could use a Buck/Boost switch mode reg for the 12V out, then feed the 5V reg from that.
A buck/boost covnverter will give an output voltage below and above the input voltage.
https://www.ebay.com.au/itm/142535580645?hash=item212fc85be5:g:CeMAAOSwLTNZ3e~1&frcectupt=true
The problem with the buck/boost converter is that when i am feeding the 12v then it will drop to some other voltage.
For example : we set the buck/boost converter to convert the 25v to 12v then it is running perfeectly.
but at the time of 12v input instead of 25v then it will drop below 12v to 9 - 10 v ..
I have mentined in the post#11 that my input DC source ranging from 25v to 12v.
dendad
Joined Feb 20, 2016
4,641
A Buck converter will need more than the o/p voltage to work, maybe 14V min i/p for 12V out.
A Boost converter needs less than the o/p voltage to work.
That is why you use a Buck/Boost as it can run from less than the o/p voltage, as well as greater than the o/p voltage.
A Buck/Boost reg will give 12V out on less than 12V in, and 12V out when greater than 12V in.
The one from Ebay is listed as.......
Module Properties: non-isolated step-up & down module (BOOST & Buck)
Input voltage: 5-32V
Output voltage: (1) continuously adjustable (1.3-35V)
Output Current: 1.5A (MAX)
Input Current: 4A (MAX)
Output power: natural cooling 20W, plus heat sink 25W (MAX) real power
Harsh_21
Joined Sep 23, 2021
12
Can you send the link for the circuit which consist of buck boost converter??
dendad
Joined Feb 20, 2016
4,641
You can Google the chips and circuits to use, but I'd recommend you buy a ready built converter as they can be fiddly to get working correctly.
And Ebay etc have very cheep boards available.
http://xlsemi.com/datasheet/XL6019 datasheet-English.pdf is the data sheet for the chip used above. Note that is can be used in different configurations, not just Buck/Boost.
https://www.arrow.com/en/research-a...st-converters-the-versatile-voltage-component has a bit of info.
Most switch mode regulator manufacturers have them. The design components and layout are pretty important and can be tricky to get right.
So, unless you really want to make your own, just buy a ready made board.
