Yes, I have seen the circuit. The current passing through parallel resistor and capacitor and the voltage will measured across them. From this configuration, I understand that the parallel RC circuit filtering the current signal only. If I'm wrong please correct me.Look at the circuit, and see if you can answer it. Hint: it does not require ANY circuit analysis.
Bob
, Correct me If I'm wrong?.
Yes, That is typo.. Thank you for the correction.If R1=R2, R3=R4 and C1=C2, then the -3dB frequency is just
f=1/(2πR3.C2)
and the gain is
R3/R1
R4=R3 and C1=C2Yes, That is typo.. Thank you for the correction.
Then, what is the formula for R4//C1?. Since more than 20 posts Im asking this formula. Please could anyone provide me?.
Perhaps you did not get a satisfying answer to this question up to now because nobody can understand this question?Yes, That is typo.. Thank you for the correction.
I want to add the C1 capacitor, parallel to the resistor R4 to filter the input signal of the amplifier.Perhaps you did not get a satisfying answer to this question up to now because nobody can understand this question?
A formula for R4||C1 ? Do you want the expression for the resulting impedance - or what?
the -3dB frequency is just f=1/(2πR3.C2)I want to add the C1 capacitor, parallel to the resistor R4 to filter the input signal of the amplifier.
hi P,I want to add the C1 capacitor, parallel to the resistor R4 to filter the input signal of the amplifier.
As far as I can see, you have two input signals. Hence, the circuit has two transfer functions.I want to add the C1 capacitor, parallel to the resistor R4 to filter the input signal of the amplifier.
As you said that in the above post, R1=R2, R4=R3 and C1=C2, and also the inverting and non-inverting signal paths must have the same impedance. Thus, the C1 and C2 should have the same value of the capacitor to keep/match the same impedance on the both inputs (non-inverting and inverting) of the amplifier. I think I understand now, Am I correct?.the -3dB frequency is just f=1/(2πR3.C2)
and the gain is R3/R1
The inverting and non-inverting signal paths must have the same impedances. That’s the whole point of a differential circuit.
Yes.As you said that in the above post, R1=R2, R4=R3 and C1=C2, and also the inverting and non-inverting signal paths must have the same impedance. Thus, the C1 and C2 should have the same value of the capacitor to keep/match the same impedance on the both inputs (non-inverting and inverting) of the amplifier. I think I understand now, Am I correct?.
Yes, the V1 and V2 are the inverting and non-inverting signals.Yes.
I am assuming that V1 and V2 are the inverting and non-inverting parts of a differential signal, not two separate signals.
To take an audio example:But, I have little confusion here, when you mention that not separate signals, what you mean by separate signals?.
Ohh.. Ok ok. I understand now and thank you for the explanation.To take an audio example:
V1 could be from a CD player, and V2 from a radio. That’s what I meant by separate.
Differential signals, although there are two signals, they are both from the same source, such as a balanced line microphone.
