Parallel Loads switched by a single transistor
Status
Not open for further replies.
cevval
Joined Dec 6, 2011
63
Happy new year to everbody, first of all.
Herebelow I have posted a part of my draft circuit diagram.
My questions to experts are as flollows: Please, see the attached diagram.
1) Is it a good way to switch on and off different loads by a single transistor. Or a separate transistor for each different load is necessary?
2) You will see that transistor base is grounded through a 10k resistor. I learned this from some where from internet. Is this absolutelly necessary or can I omit it?
3) You will also see that across terminals of the buzzer (magnetic type) a 1.0k resistor is connected. I learned this from a manufacturer's application hints. Is this absolutelly necessary or can I omit it?
Thanks for all in advance.
ScottWang
Joined Aug 23, 2012
7,509
1) You should use separate transistor for each different load is better.
2) The 10K is designed to turn off the transistor more quickly or when the input terminal is a switch, the Rbe can be turn off the transistor and you can't let B of Q3 into a floating status.
If you want to use Rbe, then you may reduce it to R25(10K)/5, but normally when you used 10K is OK, you may try to take it away.
3) If the Buz is one kind of the Inductance then you should add the Diode, 1K is designed to reduce the oscillation of Buz, if you take the 1K away and then the Buz is still working fine, then you can take 1K away.
cevval
Joined Dec 6, 2011
63
The supply voltages to loads as follows:
1)To buzzer and led on PCB: approx. 12-14 volts.
2) External led: 12-16 volt, maybe. Just to supply ground when the base input is on.
3) Base voltage: 9V
Thanks.
33,327
Sometimes you can play a game like this, but what you have to do is consider the behavior of the circuit when the transistor is turned off. In this case, the top part of the circuit still has power and ground connections. Ignoring the remote LED option, consider that you have the following path:
+12V -> R27 -> LED1 -> D11||R26 (plus possibly the buzzer) -> VR8 (wiper) -> GND
Audioguru
Joined Dec 20, 2007
11,248
With a 9V supply, the typical output high voltage from an LM224 is about +7.8V. The base-emitter voltage of the 2N2222 is about 0.7V so the 10k base resistor has a voltage of 7.1V and a current of 0.71mA.
Then the transistor saturates well when its collector current is only 7.1mA. The beeper will not be loud and the LED will not be bright.
Ron H
Joined Apr 14, 2005
7,063
Good observation.
A diode could eliminate the backfeed problem. See attachment.
Cevval, what does this mean?
cevval
Joined Dec 6, 2011
63
Good observation.
I revised and improved the schematic and attached here below according
to your recommendations. What I mean is: Remote led is on the car
dashboard cluster for giving alert already for hand brake and brake fluid
low level. Now, I am designing a circuit as an hobiest, of course with the
help of those guys at internet i.e. like you, which is about car speed limit
alerting when driving on highway. This circuit should give visiual and sound
alerts when the legal speed limits exceeded.
So I intend to use the existing led on dashboard which is for hand brake
and brake fluid level monitoring. When I believe that the circuit design
safe enough and then I will make and home-made circuit and after testing
of course, put it in a box and install under the dashboard of the car.
See below attachment for more detail for your question.​
Regards,
cevval
Joined Dec 6, 2011
63
alerts when the legal speed limits exceeded.​
of course, put it in a box and install under the dashboard of the car.​
Regards,
bertus
Joined Apr 5, 2008
23,027
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
There will be enough sites where automotive questions can be discussed :
Member selected automotive forums
Status
