paired device list view in a spinner.
Nik@
Joined Apr 1, 2021
29
Hi all Happy new year full of happiness, health and success for all.
i am trying to pass a list view in a spinner. The problem i am facing is that the list shown as should but when i click the BT device for connection nothing happens. I am posting the code below if someone has an idea i would be grateful. If further info needed please ask.
Mod: added Code type.E
C-like:
public class MainActivity extends Activity {
    final static int REQUEST_ENABLE_BT = 1;
    BluetoothAdapter btAdapter;
    BtHandler btHandler;
    Set<BluetoothDevice> pairedDevices;
    static String btCurrentDeviceName;
    private Spinner btDeviceSpinner;
    private static ArrayAdapter<String> adapter;
    ArrayList<String> listViewItems = new ArrayList<>();
    private EditText textToSend;
    Button sendButton;
    [USER=54416]@override[/USER]
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        adapter = new ArrayAdapter<>(this, android.R.layout.simple_list_item_1, listViewItems);
        btDeviceSpinner = findViewById(R.id.btDeviceSpinner);
        btDeviceSpinner.setAdapter(adapter);
        textToSend = findViewById(R.id.textToSend);
        sendButton = findViewById(R.id.sendButton);
        btAdapter = BluetoothAdapter.getDefaultAdapter();
        if (btAdapter != null) {
            if (!btAdapter.isEnabled()) {
                Intent enableBtIntent = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
                startActivityForResult(enableBtIntent, REQUEST_ENABLE_BT);
            pairedDevices = GetPairedDevices(btAdapter);
        sendButton.setOnClickListener(v -> {
            if (MainActivity.btCurrentDeviceName.equals("")){
                return;
            sendTextViaBT();
            writeData();
        btDeviceSpinner.setOnItemSelectedListener(new AdapterView.OnItemSelectedListener() {
            public void onItemSelected(AdapterView<?> parent, View view, int position, long id) {
                btCurrentDeviceName = String.valueOf(btDeviceSpinner.getSelectedItem());
                Log.d("MainActivity", "DeviceInfo : " + btCurrentDeviceName);
            public void onNothingSelected(AdapterView<?> parentView) {
                // your code here
                Log.d("MainActivity", "Nothing selected.");
Ya’akov
Joined Jan 27, 2019
10,294
You should use CODE tags to make reading your code easier. You can find a nice form in the ... menu in the menu bar to make setting the attributes easier.
