P channel mosfet
klopar
Joined Mar 13, 2017
Hi everyone,
I will need help. Can somebody help me. I made a circiut like on picture. It's working well when I connect the burden 3A. When I connect burden to 6 A the mosfet getting hot. I need your help.
Thank you
LesJones
Joined Jan 8, 2017
4,511
Check the voltage between source and drain of the mosfet when 6 amps is flowing through it I would expect it to be about 0.025 volts. If it is then it is working correctly and the mosfet will be dissipating about 0.9 watts. If it does not have any heat sinking it will get hot. I have also just noticed that if you are controlling the gate by either having the left hand end of R1 connected to Vcc or floating then the gate will be -Vcc with respect to the source (When floating) (-12 to -18 volts) and when it is connected to Vcc the gate will be - Vcc/2 with respect to the source when it is connected to Vcc. (-6 to -9 volts) I don't see how the mosfet can turn off.
Les.
LesJones
Joined Jan 8, 2017
4,511
Correction to post #4 I would expect the source to drain voltage to be about 0.15 volts, (The 0.025 figure I quated in post #4 is the on resistance in ohms.)
sorry for the error.
Les.
