It's been a while since I posted here, so hello again everyone
I've been messing some more with microcontrollers, and I'm in a situation where I'd like to switch power to a load connected to ground with the output of a uC. The microcontroller outputs are 3.3V and the supply voltage for the load is 48V. I've attached an image of what I'm thinking about, but it seems too simple to work. The FET is a P-Channel logic level MOSFET (should switch with -2.5V). In this case, would a logic high at the gate switch the 48V to the load?
Obviously, there might be better solutions. Any suggestions? I want to use this type of high side topology simply because I've never done it before, so moving the load and using an N-channel is out of the question
Thanks in advance.
