The Vin powers the microcontroller, couple of ICs and an LCD. The CAP+ (just named so, i should have named it different when posting the schematic to avoid this misconception) are screw terminals connecting to a 12V LiPo. The LiPo is connected when the Vin connectors are physically disconnected. Basically the LiPo will power the board if/when the Vin is disconnected or powered down even with the connector plugged in. The DIODE in series with CAP+ prevents the Vin from merging with the 8V rail in case the Vin is powered.If your capacitor will tolerate 8V but not 12V minus diode drop, you are cutting the margin of safety pretty thin. Why do you want 2 supplies, one to charge the capacitor and the other to run the circuit?
Second situation where both CAP+ and Vin is powered, the PSU powering the Vin also powers a buck-converter converting the +12V from the PSU to +8V for charging the supercapacitors. The Vout terminals from the Buck-converter is connected to CAP+ (the same terminal where the LiPo would be connected) which connects to the capacitor bank. Here the Vcc pin would be powered (not sure if by Vin or CAP+). The diode in series with Vin has not role here on the other hand the Diode in series with CAP+ prevents the +12V from getting to the supercaps.
