P-Channel MOSFET for simple polarity protection.
TonyAm
Joined Oct 12, 2022
87
Thank you for reading my question. I am using a P-Channel MOSFET for polarity protection with a circuit using an Arduino Nano.
(A little info about the circuit; the Nano is receiving 9V into the Vin pin and everything else is getting 5V from the 7805).
The MOSFET I'm using is from Tayda, the IRF5305PBF:
Specifications
Series: HEXFET
Transistor Type: MOSFET
Transistor Polarity Channel
Drain Source Voltage(Vds): 55V
Continuous Drain Current(Id): 31A
On Resistance, Rds(on): 60mohm@16A,10V
Which specs are important for a 9V device like mine? Is this part overkill for a 9 Volt device?
I am assuming that Drain Source Voltage(Vds): 55V, and Continuous Drain Current(Id): 31A are the important specs for this kind of use as a low voltage polarity protection?
I'm just learning about this part, not sure what to make of the specs.
Sincere thanks for any advice,
Bordodynov
Joined May 20, 2015
3,431
I advise you to put a 100K resistor in the gate and plug the Gate Source with a 0.1UF capacitor. This will limit the maximum pulse current generated by charging the capacitors. I advise you to model the scheme.
TonyAm
Joined Oct 12, 2022
87
Voltage and current. Overkill but it will work
Hello, thank you. I was wondering if you could help me understand the P-Channel MOSFET being used this way. The Voltage and current are the important specs, am I correct in assuming that I could use a part with even higher V & I rating, however a MOSFET with a lower V & I rating (lower than the operating current and Voltage of my circuit) would not work?
Thanks again,
TonyAm
38,807
That's basically true, but not complete.
You want the voltage rating to be greater than the likely reverse voltage that could be applied to the circuit.
And it's not just the current rating that's important.
You want the on-resistance of the MOSFET (from the data sheet) to provide a negligible IR voltage drop due to the normal circuit operating current.
TonyAm
Joined Oct 12, 2022
87
Great, thanks very much.
TonyAm
TonyAm
Joined Oct 12, 2022
87
I'm looking for a P-Channel MOSFET, smd type for having JLCPCB assemble for me on my PCB, any recommendations for a 9V, approx 1A circuit (as above)?
sghioto
Joined Dec 31, 2017
8,751
Thanks again,
TonyAm
The advantage is a very low loss of voltage through the mosfet compared to using a ordinary diode which may be important depending on the application
TonyAm
Joined Oct 12, 2022
87
Now I'm looking for a SOT (smd) version of the 7805, voltage regulator. Any advice would be greatly appreciated.
Sincere thanks,
TonyAm
