Hi, i am using opto as an isloation between a three phase gate driver circuit and controller(signal generator), but i met a problem that is when i connect for example INH3 and INL3(also the ouputs from opto) the same time from opto board to the driver board, and when i give INL (low side mosfet switching) signal, the Vgs of low side mosfet shows nothing, but once i unplugged the INH3 connection bwteen driver and opto, the there will be vgs waveform, the INH3 has no signal input. I am confuesed. Anyone could help? Thank you
