Output tripped off in MAX 1452 signal conditioner
prabhutechit
Joined Jul 22, 2019
Hi
I am using MAX 1452 signal conditioner based pressrue transducer with the input 5V & out put 2.5V
In that at normal condition the output is 2.5V no issue. But when i switched ON or switched OFF any equipment like Soldering station, Digital multimter, computer the out of the signal pressrue transducer is turned OFF.The output returned ON when i switched OFF and again Switched ON the 5V input.
Whenever i tried to switch ON something this issue happened. And then the output will come again once i switched OFF and again Switched ON the 5V input.
Kindly help me to overcome this ...
ericgibbs
Joined Jan 29, 2010
21,573
Hi p,
Welcome to AAC.
Sounds like some form of electrical pick up, do you have a circuit diagram to post or a photo of the project.?
E
