Output of the third wire in a DC fan
jaydnul
Joined Apr 2, 2015
175
Hi!
In a typical 3 wire DC fan, two wires are power and one is sense. i'm curious what the signal on that sense wire actually looks like. Is it the same frequency as the fan rotation? How much current can it drive? Is it open drain typically?
cmartinez
Joined Jan 17, 2007
8,877
If it's a typical PC fan, then it's BLDC. The third wire usually outputs a square wave signal whose frequency is related to its speed.
jaydnul
Joined Apr 2, 2015
175
Yeah but is it an open drain output? Will i need a pullup resistance? What is the typical driving capability of this square wave signal?
cmartinez
Joined Jan 17, 2007
8,877
Good question ... I'm not sure. But Max is right, it's best to use a small transistor to drive the LED, and the nFet's gate can be easily be driven by the fan's output wire.
Reloadron
Joined Jan 15, 2015
7,975
Yep a BLDC 3 wire PC fan
There are a few caveats to some of this which may or may not apply. If it is a PC fan with a straight 12 volts applied then no problem as they typically output 2 pulses per revolution of the fan. With 12 VDC applied most I have played around with typically run at about 2700 to 2800 RPM or about 46 to 47 revolutions per second which gives you about 93 to 94 Hz out of the tachometer out line of the fan. All that I worked with had an open collector output as illustrated by cmartienez in post #11.
Here is the slight caveat. PC fans which have some form of fan speed control generally use a PWM (Pulse Width Modulation) to control fan speed and those systems which do this do not always have a nice tachometer output. This generally won't matter but if you are using the open collector Tachometer Out make sure your pull up (shown as R in the above example) is tied to a constant voltage like 12 or 5 VDC and not to the fan power shown as Vcc above. LED flicker would be normal but you will know if the fan is turning. :)
Ron
