Hi
We have one of the KEB COMBIVERT F5 inverter drives on one of our machines. The output voltage from the drive when the motor is running should be 120VAC(phase to phase), but we are getting 220VAC(phase to phase). Also, in stand still condition there should be no output voltage to the motor but we are getting around 40VAC(phase to phase), causing the motor to hum and in some instances rotate in the reverse direction. Input voltage is 415VAC.
What could be the possible cause of such behavior?
Any information and help would be greatly appreciated. Thank you.
