Hello all ,problem i am having is this board AXBB-E see attached manual for outputs and description ,i have tried installing a 1k ohm resistor in this circuit between the two on the input to the relay board and the first relay will trigger but if i hook up another to the next input with another resistor i get nothing.
I am using the same 24 volt supply for booth boards or should i use separate supplies i am a little lost at this point or should i be using a different relay board all together board all together?
